13 years agoError when porting from SOPC Builder to QSys
Hi
Recently porting an old design from SOPC BUilder 11.1 to QSys 12.1. I have the following QSys errors: Error: System.MeasureDVI: Could not determine TOP_LEVEL_HDL_MODULE because file /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/MeasureDVI.vhd contained no modules Error: System.MeasureDVI: Could not determine TOP_LEVEL_HDL_MODULE because file /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/MeasureDVI.vhd contained no modules Error: System.mbx_core: Could not determine TOP_LEVEL_HDL_MODULE because file /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/mbx_core.v contained no modules Error: System.sh4mbx_core: Could not determine TOP_LEVEL_HDL_MODULE because file /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/sh4mbx_core.v contained no modules Error: System.ru_wrap: Could not determine TOP_LEVEL_HDL_MODULE because file /home/mkarasoff/devfiles/Clive/linxfpgawork/LINX_V4_2_b/LinxScalar/LINX_SCLR/ru_wrap.v contained no modules Each of the modules it mentions is a custom SOPC IP block. The HDL files are present in the location mentioned in the error. Is there something that needs to be added to the top levels of these cores? Any ideas? Thanks1 Reply
Solved.
I found that this is because the custom VHDL files were actually NOT present as I had thought. Somehow, they got removed while porting. Replacing them from the original archive solved the issue.
