16 years agoError: quartus_map ended unexpectedly
Hi there, I'm running Quartus II 10sp1 on ArchLinux. . When I'm trying to compile LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY my_and2 is
PORT(A, B: IN STD_LOGIC;
C: OUT STD_LOGIC);
15 years agoGoogle translate is your friend (Do not work anymore because of the https...).
But to solve the problem, you just need to do the echo. The file /etc/issue contain special char to clear the screen at boot (not ascii) and Quartus can not handle it. Why Quartus need to read this file ? I don't know and it doesn't make sens for me... So the solution it's to remove special char into that file. You can do hexdump /etc/issue to see these specials char. You can save the file before if you want :cp /etc/issue /etc/issue.back But anyway you just need to do as root this command : echo "Arch Linux \r (\n) (\l)" > /etc/issue Any way if you didn't understand this post too, I can't help you more (I am french)
