16 years agoError: quartus_map ended unexpectedly
Hi there, I'm running Quartus II 10sp1 on ArchLinux. . When I'm trying to compile LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY my_and2 is
PORT(A, B: IN STD_LOGIC;
C: OUT STD_LOGIC);
16 years agoHi,
I am on ArchLinux too (i686) and I have exactly the same problem. Friends of mine try on Ubuntu and didn't have any problem: To add more information, i have try to run quartus_map in command line/opt/elec/quartus/quartus/bin/quartus_map galileoCPLD -c galileoCPLD
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 10.0 Build 262 08/18/2010 Service Pack 1 SJ Web Edition
Info: Implemented 571 device resources after synthesis - the final resource count might be different
Info: Implemented 25 input pins
Info: Implemented 52 output pins
Info: Implemented 494 logic cells
*** Fatal Error: Unhandled exception
0xade3: ERR_STACKWALKER::get_stack_trace(void const**, int, int, void*) + 0x8f (ccl_err)
0xd6f6: err_terminator() + 0x62 (ccl_err)
0x17a0e: std::terminate() + 0x1e (dinkum_alt)
0x2a6f3: _Dinkum_std::_String_base::_Xran() const + 0x1a3 (dinkum_alt)
0x3bbeb: _Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, _Dinkum_std::allocator<char> >::assign(_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, _Dinkum_std::allocator<char> > const&, unsigned int, unsigned int) + 0x3b (ccl_gen)
0x32e96: GEN_MACHINE_INFO::get_os_name(_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >*) + 0xbe6 (ccl_gen)
0x32350: qcu_report_operating_system(QCU_FRAMEWORK*) + 0x43c (comp_qcu)
0x664eb: qcu_add_common_panels(QCU_FRAMEWORK*, ACF_FILE_CATEGORY_ENUM*, ACF::REPORT_TYPES::TYPE*, bool, bool) + 0xd5 (comp_qcu)
0x26833: QSYN_FRAMEWORK::write_reports(bool, char const*) + 0x193 (quartus_map)
0xd45c: qexe_do_normal(QEXE_FRAMEWORK*, char const*) + 0x210 (comp_qexe)
0x17cfd: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x437 (comp_qexe)
0x18b8b: qsyn_main(int, char const**) + 0x9b (quartus_map)
0x1ea58: msg_main_thread(void*) + 0x18 (ccl_msg)
0x57c8: thr_final_wrapper + 0xe (ccl_thr)
0x201c2: msg_thread_wrapper(void* (*)(void*), void*) + 0x72 (ccl_msg)
0x62570: mem_thread_wrapper(void* (*)(void*), void*) + 0xd0 (quartus_map)
0x9b20: err_thread_wrapper(void* (*)(void*), void*) + 0x2a (ccl_err)
0x57fb: thr_thread_wrapper + 0x2f (ccl_thr)
0x32cd1: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x97 (ccl_msg)
0x131df: main + 0x4f (quartus_map)
0x16c76: __libc_start_main + 0xe6 (c.so.6)
Exiting...
Abandon
