18 years agoError placing clock pin with Clock Control Block
Hello all, It appears I could use some assistance. Some background ... The device is an EP2SGX130F1508. The problem in question concerns two clock inputs. The two clock inputs are from t...
18 years agoI think only one signal can get onto the altclkcttrl block from the fabric, and it is selected statically(i.e. at configuration), rather than dynamically. The Handbook should have a section explicitly showing the altclkctrl muxes. What you're doing is fine, but you want to be careful not to switch between clocks in such a way that you get a clock glitch, which is very easy to do.
