RWeiz
7 years agoError: No EPCS layout data - looking for section [EPCS-9D6017]
Error: Unable to use EPCS device
Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_proj/software/TIJ_bsp/flash/DE10_NANO_TIJ_Engine_epcs_flash_controller_0.flash" --base=0x41000 --epcs --sidp=0x42138 --id=0x42138 --timestamp=1555660140 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --verbose
- JohnT_Altera
May I know if you are able to use older version of Quartus which is 14.1? I would like to confirm if this is happening only in latest Quartus version only. - JohnT_Altera
Hi, Could you try the method mention in https://www.intel.com/content/www/us/en/programmable/documentation/iga1446487888057.html#jrn1481229919317 (Chapter Nios II Processor Booting from EPCQ Flash)? You will need to change the device to EPCS and Configuration mode to Active Serial Mode. - JohnT_Altera
The setting looks good to me.
