15 years agoerror in simulation
i have attached my code. error is during synthesis,it says that metavalue detected,turned to null.and gives null output.:cry:
15 years agoHi technovlsi,
You need to post more info. in fact you need to tell us about your testbench and how you are inputting into the LUT module. The LUT module itself has all its values defined right from reset. So it is likely your observation is wrong or the way you use the LUT.
