8 years ago
Error in simulation due to unknown generated files in Modelsim
Hi all,
I have made a Modelsim project and added 3 files to the project. After compilation, I have simulated pkt_enco_tb file as it is my testbench file. but I am getting errors as shown in attached image.
Also, I have seen that after compilation, unknown files were generated like 'pkt_enco_tb_sv_unit' and 'pkt_encoder_sv_unit', I have attached an image for this. So I want to know that what is the significance of these files?:confused:
and how to solve this error?.:confused:
thank you.
    --- Quote Start ---
    Can you share the files?
    To debug
    1. Can you try to simulate individual .v/.vhd file first?
    And find the file which causes the problem. Also, try to check the logic of it and its integration to the top file.
    Anand Raj Shankar
    --- Quote End ---
    I have solved this issue by the refreshing library in Modelsim before simulation.
    Somehow I got the solution by changing the order of files in the compilation. And keep the package files in the same folder where my testbench is. Below is my testbench code.
    I have come across another issue. I am using 2 package files, in the first package file, I have defined multiple byte structures. And using the first package I have defined structures of the group of bytes. So my case is, from testbench I have to write individual byte as per the first package and I have to read group of byte from second package. I am able to write in frist package but I did not get it from second package. So I want to know that is it possible ? if yes then How? and If no then what I can do for that?
    To debug
    Anand Raj Shankar
    --- Quote Start ---
    The images are not clear, attach the transcript.
    Are you trying to simulate an individual IP / Own soc design?
    Can you share the design?
    Anand Raj Shankar
    --- Quote End ---
    Hi, now you can see the images I have uploaded high-resolution images.
    And yes, I am trying to simulate my own design.
    Anand Raj Shankar
