ruma
2 years agoError: fpga compiler command failed with exit code 1 (use -v to see invocation)
Hello everyone!! I have the next problem when i try to use the stratix 10 node 143, with the next line: make fpga. I can emulated with the next line: make fpga_emu, and the program es correct, but ...
BoonBengT_Altera
Moderator
2 years agoHi @ruma,
Noted with thanks on the details provided.
As mention you are using the devcloud environment to run the mention design.
Just to check does the simulation compilation completed successfully as well?
And we would like to replicate the same to narrow down the issues, could you provided the URL of references design that you are referring to? That would be a great help.
Best Wishes
BB
- ruma2 years ago
Hello BoonBeng
Yes, the simulation compilation was completed successfully.
This is the URL of referense.
Thanks. Regards.-
Ruma
