17 years agoError due to always enabled I/O buffer
Hi all, I had generated a SOPC system using sdram controller, jtag, 2 pio and nios. When I compile the design, it shows error as shown below: *************************** Error: The node ...
15 years agoI'm having exactly the same issue.....
*************************** Error: The node "try:NiosII|sdram_0:the_sdram_0|za_data[11]" has multiple drivers due to the always-enabled I/O buffer "try:NiosII|zs_dq_to_and_from_the_sdram_0[11]" *************************** Can somebody suggest some solution???? This error relates to the files generated by SOPC.
