17 years agoError due to always enabled I/O buffer
Hi all, I had generated a SOPC system using sdram controller, jtag, 2 pio and nios. When I compile the design, it shows error as shown below: *************************** Error: The node ...
17 years agoI had found the source of the errors and fix it. It is because the node is not connected properly.Thank you.
