13 years agoError: CONF_DONE failed to go high in device 1.
Before anyone comments on this, I have searched the forum and read everything I have found on the internet with people getting this error message. :) I'll try to post as much relevant information ...
13 years agoHey, so you've got your instructions... Come on - take some tiny wire and do it, it's just only a FBGA... :-)
(Sorry for the sarcasm) Well - based on the layout, perhaps you can use a small drill to open the connection of MSEL1 (H12) to GND by drillling the via (my Layout is somewhat standard and thus any Pad for the BGA is routed to a via crossing the complete board (no burried via). If your's is similar, maybe the internal weak pull ups will do the job to get the system running.. Ok - this still is not as recommended in the handbook (don't leave MSEL pins floating)... Except some additional minutes of worktime there seems to be less to loose, as the board itself in the actual configuration seems to be unuseable so far..
