16 years agoError after adding support for PIO BUTTON for nios 2
Im trying to add the pio buttons driver for the DE2 board , but after doing
>make menuconfig and check support for PIO BUTTON , after that the compilation of kernel fails giving this error : drivers/char/altera_pio_button.o /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c:20:35: linux/devfs_fs_kernel.h: No such file or directory /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c:87: warning: initialization from incompatible pointer type /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c: In function `button_start': /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c:113: error: `SA_INTERRUPT' undeclared (first use in this function) /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c:113: error: (Each undeclared identifier is reported only once /media/disk/nios2-linux/linux-2.6/drivers/char/altera_pio_button.c:113: error: for each function it appears in.) can somebody tell me please how to fix this error , and is there a way to access or display data on the 7 segment on the de2 board . Thanks all1 Reply
hi,eabbas:
I have met the same problem,did you reslove it?Thank you,please tell me how if you have finished it!
