18 years agoError 10822?
HI ALL,I just wrote a vhdl program.When i compiled it in QuartusII,it gave me some error 10822:"Error (10822): HDL error at aichselect.vhd(63): couldn't implement registers for assignments on this cl...
18 years agoHello,
basically you shouldn't try to implement a clock synchronous construct within a case structure. If the compiler possibly accepts it, it would end up in a gated clock. Apparently he doesn't, may be for additional reasons I didn't yet see. The rising_edge(clk) should always be the outermost condition in a process, only accompanied by an asynchronous reset condition if applicable. Regards, Frank
