14 years agoError (10533): VHDL Wait Statement error
Hi, I called in a CPRI IP from Altera Quartus II which created a testbench tb_altera_cpri. While trying to compile this testbench I encountered an error: Error (10533): VHDL Wait ...
13 years agoI just encountered the same problem. This happened when I accidentilly set the testbench file as top level entity. So as long as you don't do that, and keep to the correct syntax, you should be fine.
--this line is here just to make the post long enough.
