13 years agoError (10528): VHDL error at lcd.vhd(135): value "0" is outside the target constraint
I had upload a vhd file, please help me check. The error is at the line 135 : signal lcd_cmd_ptr : integer range 0 to LCD_CMDS'HIGH + 1 := 0; I have no any idea about it. Please help me solve...
13 years agoInfo: *******************************************************************
Info: Running Quartus II Analysis & Synthesis Info: Version 9.1 Build 222 10/21/2009 SJ Web Edition Info: Processing started: Sat Dec 01 15:14:44 2012 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off lcd -c lcd Info: Found 2 design units, including 1 entities, in source file lcd.vhd Info: Found design unit 1: lcd-Behavioral Info: Found entity 1: lcd Info: Elaborating entity "lcd" for the top level hierarchy Warning (10445): VHDL Subtype or Type Declaration warning at lcd.vhd(135): subtype or type has null range Error (10528): VHDL error at lcd.vhd(135): value "0" is outside the target constraint range (0 to -2147483623) Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 1 warning Error: Peak virtual memory: 223 megabytes Error: Processing ended: Sat Dec 01 15:14:45 2012 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 1 warning
