15 years ago
Error : Could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji
Hi everyone,
I have a custom board with an EP3C10 wich I access with the JTAG port. I have an USB Blaster to download both the vhdl and the code for the nios2. I'm working with windows 7 32bits with Quartus2 10.1 sp1.05.
Yesterday, everything worked fine, but today morning, I cannot download the nios2 software.
I manage to download the vhdl and the output of the FPGA run fine so I understand that my FPGA and the JTAG port are both OK. and so do the USB Blaster.
In Eclipse when I select "run configuration", on the "target connection" tap, I have this error message :
system console: could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji.ajicable
and when I click on "refresh connection", nothing happen! Well, the button is locked for 2 second and then it come back to its previous state...
Has anyone any clue to solve that ?
Thank you
    hi!
    i have had a long discussion with wombat for building a connection from matlab to my nios2. after many hours of reading and searching, i suppose that the best possibility should be, to use systemconsole via matlab (=> Matlabapi) - wombat told me.
    after a long time i finally can create a java object in matlab for establishing the connection.
    the problem:
    when i use "L1 = com.altera.systemconsole.matlabapi.SystemConsoleLink" the object is created successfully but i get the message:
    05.08.2011 09:42:55 com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery run
    INFO: Finished initialization
    05.08.2011 09:42:55 com.altera.systemconsole.internal.core.SystemConsole logSevere
    SCHWERWIEGEND: Could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji.AJICable
    java.lang.RuntimeException: java.lang.NoClassDefFoundError: Could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji.AJICable
    at com.altera.systemconsole.internal.core.SystemExecutor$3.run(SystemExecutor.java:438)
    at com.altera.systemconsole.internal.core.SystemExecutor$TaskComparator$ComparatorPolicy.run(SystemExecutor.java:207)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.altera.systemconsole.internal.plugin.jtag.aji.AJICable
    at com.altera.systemconsole.internal.plugin.jtag.aji.AJIConnectionProvider.queryCables(AJIConnectionProvider.java:48)
    at com.altera.systemconsole.internal.plugin.jtag.JtagConnectionProvider.doRescan(JtagConnectionProvider.java:174)
    so i get the same error when i try to build a connection via matlabapi and the problem is - ???
    when i start system-console.exe (from the E:\altera\11.0\quartus\sopc_builder\bin) system-console can establish the connection and i can send tcl-commands.
    ok today i was able to produce the error with an other file.
    i have a copy from system-console.exe from an old installtion (i set up a new system win7-64 ->winXP-32) and its possible to start it but i got the same error like in matlab. problem with jtagdni.dll.
    mhh - i have no idea how to fix it ???
    do you have an idea now how you fixed your problem?
    I'm glad you've got it working again.
    The error message occurs because that Java code is unable to load it's native library, JtagJNI.dll.
    What I suspect happened here is that your path had somehow made windows load the wrong versions of the native library - one which is not compatible with the Java - or that that DLL found the wrong version of a dll it depends on. (The windows DLL loading rules are byzantine, and Java doesn't really provide any good ways to override them)
    But I'd like proof before jumping to conclusions.
    Hi, I forgot to reply to this thread. The system is working again.
    But, because there is a but, I can't explain why it wasn't working and why it works now. I have tried several times several way to have my download to success:
    - I have closed eclipse and started it again => no use.
    - switched off the computer and reboot => same here.
    - re-install the USB driver => again it wasn't that.
    - others stuff I can't remember.
    And every time, the same error message appeared.
    But once, and I don't know why, it worked, and since, I don't have any problem anymore. I should have done something to change the behavior but I don't know what it is.
    To answer your question : yes, I have quartus 9.1sp2 and quartus 10.1sp1.05 installed.
    Can I ask a couple of questions about your setup?
    What's on your path when you run Eclipse?
    Do you have multiple copies of Quartus/ACDS installed?
