REics
3 years agoEquivalent pins in different packages? (10CL016YU256 vs. 10CL016YU484)
Hi there,
Due to part availability I need to change my existing 256pin design to use the 484pin version of the same Cyclone 10CL016 device. I don't need any extra I/Os, and ideally would like to u...
AqidAyman_Altera
3 years agoHi Rolf,
Unfortunately, migration capability only possible if there are in the same packages where you can use the same *.rbf file, this is from what I understand. If both devices are in the same migration paths, it is possible to do I/O migration.
However, from you case, both devices are in different packages. So, I would suggest you update the design accordingly.
Aqid
