13 years agoEpcs16 configuration
Can i configure the serial configuration device (epcs16) without having the fpga in the circuit? If so how? I couldn't find any documentation on it
13 years agoHi Erick,
--- Quote Start --- Is an Altera part.. I got it from Digikey PN# 544-2567-5-ND. --- Quote End --- Ok, so its an EPCS16SI8N. Since you purchased it, I assume it has been loaded on a custom board. Have you probed the board with an oscilloscope and checked the waveforms? You can also talk to the flash directly, eg., create a Qsys system with a PIO component and connect the pins from the PIO to the flash. I've used that method to test SPI and QSPI flash devices. Cheers, Dave
