13 years agoEpcs16 configuration
Can i configure the serial configuration device (epcs16) without having the fpga in the circuit? If so how? I couldn't find any documentation on it
13 years ago --- Quote Start --- Thanks for your reply. But I am still confused. When I try to flash the EPCS device, Quartus programmer shows an error saying the silicon ID can't be recognized. Can Quartus programmer actually load the .pof file into the epcs device? --- Quote End --- Is the EPCS device on the board an Altera part or a Spansion part? If its a Spansion part, then you need to disable the ID check - see this thread http://www.alteraforum.com/forum/showthread.php?t=38703 Cheers, Dave
