18 years agoEPCS16 AS Can't Verify Device (General AS Programming Issues)
I have a custom board and the TerasicBlaster (USB Blaster Clone) and at least some communication seems to start OK (reports Device 1 silicon ID is 0x15). I can Erase and Blank Check successfully mos...
18 years agoThanks for the reply. I'm trying again on my 2nd board just to see if anything becomes apparent. I had a little difficulty soldering the FPGA because while I'm used to soldering QFPs these leads seemed more delicate than I'm used to. Things seem to be going better soldering it this time around. I also built the EPCS circuit first, since I know now it can be programmed on its own at it worked first time.
Have my fingers crossed - will keep you posted. -JNS.
