15 years agoEPCS: Free memory?
Hi all! I have a cyclone2 board including EPCS device. On the cyclone2 i have got a nios2 running. The configuration for the cyclone2 and the software for the nios2 come from the EPCS device. ...
15 years ago --- Quote Start --- From the fpga configuration file (.sof) and the Nios firmware file (.elf) you know exactly the epcs space required. --- Quote End --- While this is mostly true, when using the default bootloader it's not exactly the case. While the software data is stored right after the FPGA configuration bitstream in the EPCS/serial flash device, it is in "boot record" format, not raw binary format. The tools will generate the "flash/SRecord" data for you using sof2flash, bin2flash, and elf2flash. You can see the size that these SRecords take on flash/epcs by running
nios2-elf-size <your_elf_flash_filename>.flash Once you have this information, you should be able to determine where best to place your additional data. Regards, slacker
