18 years agoEPCS configuration image and data
Hi, I try to program EPCS with configuration image and data by the NIOS ll flash programmer. In the Flash Programmer menu I placed the data file (hex) with some offset from the EPCS base address. ...
18 years agoYou probably need to access your EPCS through EPCS controller and its API which I think, makes use of CFI drivers in lower base. You can go through EPCS controller device core datasheet for more information.
