15 years agoEPCS Config via SOPC Builder component in normal user design
Hi, I just want to make sure I have understood the documentation correctly and my plan can work. We want to update the bitstream in our EPCS16 + Stratix2 system respectively our EPCS64 + Strati...
15 years agoHello Flintstone,
I have a query in relation to an old thread which was initiated by pinkymacy and to which you contributed entitled avalon_mm interface of tse.
I'm having the same issue with waitrequest remaining high when I try to interface to Altera's SDRAM controller. I see from your response that you were able to solve the issue but I didn't fully understand how you did it. Would you be able to describe in more detail how you solved it or if it's easier, send me a sample of the code you used? best regards, John
