13 years agoEPCS-16 / CYCLON-IVE flash problem @ DE0-Nano board
Hallo,
Sorry if I broach the subject EPCS-16 again, but I have a big problem and can not find a solution so far. I have 2 DE0-Nano boards. One is working fine, the the other makes problems, only when I try to flash my sof+elf design to EPC. Enclosed, please find my test design and the error message file from the bad DE0-Nano board. My design is based on SD-RAM but I have the same problem if I use the FPGA onboard RAM. Very funny is that I am able to flash the jic file via Quartus programmer on both DE0-Nano board. So, I think the problem is not related to a faulty DE0-Nano board. I am using Quartus II 11.1 SP2 and NIOS II 11.1 SP2 Does anyone know if there is a hardware revision problem within the DE0-Nano board ? Could it be raise conditions and a fix is already available ? I will order an additional DE0-Nano board but if someone ca try to run my test-design on your Nano board would also be a great help. Any other ideas , concern is welcome. Many thanks in advance, Reinhard1 Reply
Sorry, posted the thread in the wrong section.
More details can be faound here: http://www.alteraforum.com/forum/showthread.php?t=38703
