8 years agoEpc1pi8 vs epc1pi8n
what differnce is between the epc1pi8 and epc1pi8n? and the two is compatible is software? and now ,I programmed the pof file which is suited for epc1pi8 into epc1pi8n,and the fpga will wo...
8 years agoHi,
Only package difference. If you have all the original design files, generate .pof Programming Files with the previous .sof. With which you can program the device. Can use Quartus 13 or older version. For the new design, both the part numbers are not recommended. Refer below link https://www.mouser.com/pcn/intel_corporation_pdn1708_rev_1.0.0.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
