15 years ago
EP3SE260 Configuration problem!!
hi all:
I have a circuit board which is designed by refence dk-dev-3sl150n !!
it works when i use 3sl150n !!!
when i change device to 3se260, it failed to load from flash(max ii pfl)??
if the design of dk-dev-3sl150n suit for 3se260??
or i need to change something for change device??
watson
    I have changed the device of my vhdl design!!
    The problem is about hardware ??
    The bitstream is not compatible between devices! You must regenerate the design with according pins and constrains to Your different FPGA.
