15 years ago
EP3CLS200 cann't load program automatic?
I use EP3CLS200, I programed the EPCS64 by AS mode, At first the program can be running normally, but yestoday I find the program can't run,
when I test the DCLK pin of EPCS64, there is no clock when I power up, but I also can programm the EPCS64 in AS mode. the 3.3v and 1.2V all ok,
but I don't konw where is problem ?
Thanks for you answer.
    check the jtag signals with a scope. Is the FPGA getting his 1.2 and 2.5V supplies?
    How to test EP3CLS200 is ok?
    EP3CLS200 can't access JTAG chain?
    message: can't configure device, expected JTAG ID 0x2077 ,but JTAG ID code 0x0000000;
    The fpga is broken?? How can I find the problem?
    I change the EPCS64, BUT the problem is also there.
