15 years agoEP3C25 nStatus 1V
I have five EP3C25 borad, 3 of them are working well. But the rest 2 will sometimes boot fail. The working mode is AS or fast AS from EPCS4. There're 10K pull up on nStatus, nConfig, Conf_done, MSELs...
15 years agoThere's still one question. Will the MSEL pins be read after each nConfig toggle? If so, the problem may quite probably on the MSEL pins. Because I found that there were more failure occured on nConfig release than on POR. For several times the loading after POR was OK but then reset nConfig failed.
