15 years agoEP2C5Q208C7 Cyclone II device configuration problem with EPCS1 in AS mode
Dear all, I am trying to configure Cyclone II EP2C5Q208C7 device with EPCS1 in Active serial mode using a USB blaster. I am not using JTAG configuration on my board so connected the TDI/T...
15 years agoCould somebody help me on this?
Now i have got another board wired and have put the recommended 1k ohm pull up/down resistors on TDI/TMS and TCK Pins while connecting them to VCC and GND. my device got programmed fine for many a times and worked fine. But today i tried to reprogram it again and got the following error "can't recognise the silicon ID for device 1" why this could happen? It was working absolutely fine and suddenly this reprogram did not work. If somebody could suggest any solution plz do suggest. I need it desperately!!! thanks in advance!!! mohan
