Firaseng
2 years agoEP1K30TI144-2 FPGA
Hi All, I urgently need to know if I can swap the EP1K30TI144-2 FPGA with EPF10K10AQI208-3 does not require much code changes? it will be used in new product development at my company.
FvM
2 years agoWhy would you replace a about 25 year old device with an even older one? Smallest device of recent Cyclone 10 or MAX 10 series has much more resources.
Porting VHDL logic should be no problem at all. Why don't you simply try to compile your project for the different device?
Firaseng
2 years agoHello FvM,
I am trying to avoid the Max 5 or Max 10 because of the pinout difference from my original IC , EP1K30TI144-2 also due to concerns that the code may not compile and we dont have much time to trouble shoot it.
For the reasoning behind going with EPF10K10AQI208-3,it was because its available to buy immediately and that the pinout is similar to that of the EP1K30TI144-2.
