15 years agoentity keyword
What is the difference between "entity" and "entity work" ? I am seeing these right before port map statements. I understand what an entity is but have never seen the word "work" follow it as a keywo...
15 years ago --- Quote Start --- direct instantiation is awesome --- Quote End --- Its good for quick-and-dirty checks of code, but it introduces a compilation-order dependence which can be annoying. If the compiler sees u1: entity work.mycomponent ... before it has actually compiled mycomponent into work, then it will choke. If however you have a component declaration either in the file where you use the component, or in a package that the code references, then the compiler will only look for mycomponent after it has processed all the VHDL files. So, its 'awesome', but not perfect :) Cheers, Dave
