15 years agoEmulated LVDS Resistors Placement
Hi, I want to create 2 external LVDS clock signals to clock 2 ADC chips. I use a EP3C16Q240 device. According to the datasheet I have to use LVDS_e_3r solution, since the PLL Outputs are placed at th...
15 years agoThank you ppl for your replies. The clocks will run at 320 MHz. Is this ok or should I use an external clock generation/distribution chip?
