15 years agoEMP1270 BGA burning up
On a new design we have a repeated problem that the EMP1270 developes a short between pwr and gnd and smokes. Single 3.3v supply operation, all other devices on board on same supply. The only exposed...
14 years agoEven if the thread is inactive for a year ...
I have a very similar problem with our boards. We are using the same device and package, Sometimes when switching on the CPLD gets burned immediately and the 3.3.V power rail has a shortcut. Getting the CPLD off from the PCB, I could verify that at least in one case VCCINT had a shortcut (below 5 Ohms) while VCCIO was ok. The power supply is realized using a linear regulator 5V -> 3.3V. 5V are generated by a switching regulator. Could you figure out the reason for the failure on your boards ?
