15 years agoEMP1270 BGA burning up
On a new design we have a repeated problem that the EMP1270 developes a short between pwr and gnd and smokes. Single 3.3v supply operation, all other devices on board on same supply. The only exposed...
15 years agoThey didn't build them with the MAX II G devices did they..
VCC-INT is 1.8 V on this variation, so if you are using 3.3 I could see them burning out in that case. EMP1270G ? instead of EMP1270? Other than that do you have any 5V devices talking to it? There's an internal clamp diode function to make them the io's 5 v tolerant.. Do the parts run hot when they power up ok? or do they just get hot when they burn out? Pete
