EMIF TOOLKIT failure, see screenshot. Added Hard Memory controller to design, but calibration results show a failure in the EMIF toolkit. what is the source of the error?
I'm using USB blaster II indeed. I'm working w/ Cyclone V E family w/ HMC, so no ARM cortex
Is the cyclone V E device supported? according to this, the cyclone V SOC is not supported, so I am wondering if the E is supported.
section 17.5 of this doc https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/external-memory/emi_ip.pdf
Dear ALee11,
May I know what Quartus version are you using? And if it is old version then I suggest you to try use newer Quartus version and see if it the error still there or not.
Next, I recommend you to create the example design, place it into same location and re-try the toolkit.
Also, without using emif toolkit, can you try to check the calibration status signal and see it is pass calibration? I am asking this because when there is no pll_ref_clk supply to the emif IP, it will cause the linking fail since the toolkit cannot detect anything from emif ip.
Hope this is helpful 😊
NAli1
