10 years agoEmbedded Jam STAPL Player, long programming time
Hello, I have ported the Jam STAPL bytecode player to my embedded processor in order to program MAX 10 devices. So far the programming works fine. However, it takes ages for the player to get t...
10 years agoHi Marko,
I assume that a verify part of the programming action brings the significant portion to the pgm time. The player has to compare read and expected data bits from the actual data shift and evaluate the result. This is the gap I suppose. I would recommend to generate a SVF file for the same device and check it as it is much easier to understand what is going on. Best regards, Martin
