10 years agoEmbedded Jam STAPL Player, long programming time
Hello, I have ported the Jam STAPL bytecode player to my embedded processor in order to program MAX 10 devices. So far the programming works fine. However, it takes ages for the player to get t...
10 years agoHello Martin,
thank you for the response. Speeding up the TCK frequency would mean I would disobey the timing the Jam player dictates. Surely this could work inside reasonable bounds. I agree with you that this would bring only a small improvement. The real problem is the duration of the inter-packet gaps. Maybe they originate from the internal structure of the STAPL file and how the player processes the file as you described it. But what is the player doing in this gaps? Is there another delay function or is it waiting for an external signal? Since I need an embedded update functionality using an external programmer is not an option. Best regards, Marko
