15 years agoEfficient Verilog coding style
When I changed from using MegaFunctions to Verilog and used wires for the combinatorial logic there was higher speed and less resources(I think). Specifically it was for an ALU, so it seems the ALUT...
15 years agoThe alu block was created from the .v file. You should see the .v if you open the design file for the alu block. I will attach it as a separate file later.
