MichaelB
6 years agoDynamic reconfiguration of E-Tile with different data rates
Hello! I've a question regarding the possibilities of the dynamic reconfiguration of the E-tile transceivers. I'd like to instantiated two different transceiver settings with four channels pe...
- 6 years ago
Hi Michael,
As I understand it, you have some inquiries related to dynamic re-configuring the individual E-Tile XCVR channels in NRZ mode with two different data rates. I presume that you are using the Native PHY in PMA direct mode. There should be no issue to performing individual dynamic rate change. You may make use of the Embedded Reconfiguration Streamer and Multiple Reconfiguration Profiles in Native PHY to facilitate your rate change as well.
CheepinC_altera
6 years agoYou are most welcome.
