18 years agoDynamic Memory Allocation
Let's say I'm instantiating an on-chip FIFO memory core in SOPC builder, and I want this to be a "array of arrays". (Does this make sense), and if so, is this feasible?
18 years agoSo you may instatiate a FIFO in order to save your pointers in it, and the FIFO output will be connected to the read_address of a RAM (or ROM if needed) which will be filled with your arrays. Is this a suitable solution for you?
