TomM
5 years agoDual Configuration IP on MAX10
Hi, I have got a problem with the Dual Configuration IP on a Max 10M08DAF256I7G. I'm using Quartus Version 17.1. I write the config_sel_overwrite and config_sel at Offset 1 Read the busy signal ...
JohnT_Altera
5 years agoHi,
I would suspect that the state machine is causing the issue. Not sure if you are able to use the workaround that is working for all the board?
