TomM
5 years agoDual Configuration IP on MAX10
Hi, I have got a problem with the Dual Configuration IP on a Max 10M08DAF256I7G. I'm using Quartus Version 17.1. I write the config_sel_overwrite and config_sel at Offset 1 Read the busy signal ...
JohnT_Altera
5 years agoHi,
How about the host clock frequency that is connected to the dual configuration IP?
TomM
5 years agoHi,
you mean the clock that is connected to the clk input of the dual config IP? This is the 40 MHz clock at the output two of the internal PLL.
