TomM
5 years agoDual Configuration IP on MAX10
Hi, I have got a problem with the Dual Configuration IP on a Max 10M08DAF256I7G. I'm using Quartus Version 17.1. I write the config_sel_overwrite and config_sel at Offset 1 Read the busy signal ...
JohnT_Altera
5 years agoHi,
After you performed reconfiguration, do you try to read the offset 3 to see it it is busy?
- TomM5 years ago
Hello John,
yes I do. The sequence in the state machine is
- addr="000", writedata = "01"
- addr="000", writedata = "01", write='1' (triggering the reconfiguration)
- addr="011", read='1'
- addr="011", read='1' and wait till readdata(0) is '0'
