11 years agoDS-5 debugger "run" or "start" option lead HPS to reset
Hi, I have 2 boards with Cyclone V SoC. One is the Arrow SoCkit and the other is our custom one. There are DDR3 SDRAM installed in Arrow and LPDDR2 SDRAM installed in custom board. I've made prelo...
11 years agoIt seems to me I've fixed this issue :)
The pitfall is linker script: *.ld. The default linker script by Altera from Quartus directory assumed there are 1024 Mb of memory installed on the board. But there are only 512 in our custom board so debugger probably doesn't allow to start application which was linked for 1Gb SDRAM. I've customized linker script for myself:MEMORY
boot_rom (rx) : ORIGIN = 0xfffd0000, LENGTH = 64K
oc_ram (rwx) : ORIGIN = 0xffff0000, LENGTH = 64K
/* Need to have 64bytes available before start of program, to store the mkimage header */
ram (rwx) : ORIGIN = 0x100000 + 0x40, LENGTH = 511M - 0x40
} and it starts work! The real problem is that it's not obvious at all. Maybe for ARM guru, but not for RTL designer! The lack of programming documentation gathered in UG is the major issue I think...
