11 years agoDS-5 debugger "run" or "start" option lead HPS to reset
Hi, I have 2 boards with Cyclone V SoC. One is the Arrow SoCkit and the other is our custom one. There are DDR3 SDRAM installed in Arrow and LPDDR2 SDRAM installed in custom board. I've made prelo...
11 years ago --- Quote Start --- This is my terminal output: <snip> I've tried it excepting enabling semihosting (I do it after preloader due to it is unhosted one). Here is output in debugger:
WARNING(TAB139): Semihosting was enabled after the target had started running so may not work correctly. Enable semihosting in a target initialization debugger script or with an image <snip> --- Quote End --- Try moving the "set semihosting enabled true" before the initial "run" command in the script. This will run the unhosted uboot with semihosting, but this should be okay. If I run on my board with semihosting enabled before the first "run" with an unhosted u-boot this works and directs output to the uart. I also do not see this warning. I believe you need to try to remove the above warning from DS-5 regarding that it may not work correctly.
