15 years agoDriving differential clock from Cyclone III Dev Board to daugther card
Hello, I am attempting to drive a differential clock out of the Cyclone III Development Board (EP3C120F780) to the "Data Conversion HSMC" daughter card. I want to clock data to a 14-bit DAC on...
15 years agoI tried removing the ALT_OUTBUF_DIFF so as to let the compiler assign the negative output. But this does not solve the problem. I still get the follow error:
Error: Pad 284 of non-differential I/O pin 'DAC[1]' in pin location AE27 is too close to pad 282 of differential I/O pin 'DAC_CLK_OUT_P' in pin location AC26 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
