15 years agoDownloading previous versions of documents
I am trying to download the Altera Verification IP Suite User Guide Version 2.0 January 2011 and its accompanying design file. But I am being directed to the latest Version 3.0 and design file if I u...
15 years ago --- Quote Start --- But at step (d) when I type s, I get the following error message:
# ** Error: (vsim-3010) - Module 'sopc_system_tb' does not have a `timescale directive in effect, but other modules do.# Region: /sopc_system_tb/dut/the_master_bfm/master_bfm
Any suggestion on how to handle this error? --- Quote End --- The vsim command should have a '-t ps' option in its command line, so it should work. I've seen this as a warning in simulations, but not as an error, so perhaps there is an option that can be changed to suppress this error. Which version of Modelsim are you using, i.e., what do you get for vsim -version? Note that the error is in the Altera-generated BFM code. Cheers, Dave
