13 years agoDownload configuration and data to EPCS
Hi everybody i am using EP3C25U with EPCS16. I want too download FPGA configuration (with NIOS2) to EPCS through jtag. In addition to that i want to add some initial/setup data. The idea i...
13 years agoHow are you currently handling the NIOS code? Just do the same thing, but with a different address.
If you're doing this with a .JIC file, just create another .hex file with your "init data" in it, and add another section to your .JIC configuration. Following these instructions, http://www.altera.com/support/kdb/solutions/rd10132010_126.html you simply repeat step# 11 except maybe use Absolute addressing to keep your "init data" at fixed location. If you're not doing this with a .JIC file, the instructions are roughly the same: just do whatever you're doing with the NIOS firmware, but at a different address.
