11 years agoDoes the 'remote update' block actually work on Cyclone V?
I'm trying to get the 'remote update' (ie the reload the fpga from EPCQ) block to work on a cyclone V using quartos 14.1.
I've managed to expose the epcq pins to 'user' logic and can successfully update the epcq from a .pof file. (If you add the 'JTAG to EPCQ bridge' you get an option to expose the pins that generates a 'test_sfl' component.) I've also instanciated the 'remote update' block and linked it to an avalon slave. If I then try to read any of the 'parameters' (aka registers) I get 1s for all the defined bits and 0s for the others (so parameter 0 (reset reason) returns 0x1f). Writes to 'page select' are ignored (reads back 0xffffff). Looking inside the remote update block there is a 'CYCLONEV_RUBLOCK' block. With signaltap I can see some serialised accesses to the block - including my write data, but the output bitstream is always 1s. I've not tried to force a reconfig - I want to know I've set the base address first. Anyone any ideas? David FWIW: Getting factory/user images to be useful is going to be 'interesting' since we are (effectively) a PCIe card. We may load the 'user' image on request from the Linux kernel - when we can reprobe the PCIe bus.11 Replies
Are you reading the boot address during in factory image or in application image? Typically you should the boot address during in application image.
