15 years agoDoes a configured FPGA need loading a configure file and initialization at power on?
Hi, Everyone, I am a CPLD user and thinking to use a FPGA (Cyclone II) for my next design. I have a FPGA beginer's question. Does a programmed/configured FPGA (Cyclone II or III) need to load a co...
15 years agoThere are multiple methods for loading the configuration data. If you have a micro already, in your design, then having a micro due the job is usually preferable, because you already have flash for it's program space. However if you don't the various families also support self programming through a serial flash device. (Active Serial Mode)
Although Altera sells their own flavor of the serial flash devices, most standard serial flashes work for this purpose. (See numonix/ST) Pete
